Arduino kezdő
- Bitmanipulátor
- Csatlakozott: 2015. december 8. kedd, 19:52
Re: Arduino kezdő
Köszi! Azt hiszem menni fog. Ha sikerül, akkor közzéteszem, másnak már ne kelljen szívnia!
Bagi
Bagi
Re: Arduino kezdő
// Created by Kevin Elsenberger //
// June 2, 2013 //
// elsenberger.k at gmail.com //
//Needed to access the eeprom read write functions
#include <EEPROM.h>
long number1 = 123456789;
long number2 = 987654321;
//This function will write a 4 byte (32bit) long to the eeprom at
//the specified address to address + 3.
void EEPROMWritelong(int address, long value)
//Decomposition from a long to 4 bytes by using bitshift.
//One = Most significant -> Four = Least significant byte
byte four = (value & 0xFF);
byte three = ((value >> 8) & 0xFF);
byte two = ((value >> 16) & 0xFF);
byte one = ((value >> 24) & 0xFF);
//Write the 4 bytes into the eeprom memory.
EEPROM.write(address, four);
EEPROM.write(address + 1, three);
EEPROM.write(address + 2, two);
EEPROM.write(address + 3, one);
//This function will return a 4 byte (32bit) long from the eeprom
//at the specified address to address + 3.
long EEPROMReadlong(long address)
//Read the 4 bytes from the eeprom memory.
long four = EEPROM.read(address);
long three = EEPROM.read(address + 1);
long two = EEPROM.read(address + 2);
long one = EEPROM.read(address + 3);
//Return the recomposed long by using bitshift.
return ((four << 0) & 0xFF) + ((three << 8) & 0xFFFF) + ((two << 16) & 0xFFFFFF) + ((one << 24) & 0xFFFFFFFF);
//Adding a delay in order to have the time to open the
//Arduino serial monitor.
delay(5000);
//Starting at the first byte on the eeprom.
long address=0;
//Writing first long.
EEPROMWritelong(address, number1);
address+=4;
//Writing second long.
EEPROMWritelong(address, number2);
address+=4;
Serial.println("If numbers are equals, it's working !");
Serial.print(number1);
Serial.print(" and ");
//Readind and sending first long.
Serial.println(EEPROMReadlong(0));
Serial.print(number2);
//Readind and sending second long.
Serial.println(EEPROMReadlong(4));
Re: Arduino kezdő
Lehetséges, hogy ezzel nagyon hamar haza vágja az AVR-ben levő EEPROM-ot?
Re: Arduino kezdő
Ez minta az írás-olvasásra.....
Nem ott kell hagyni folyamatos írásra
- Bitmanipulátor
Re: Arduino kezdő
Nagyon köszönöm!
Rengeteg időt spóroltál meg nekem ezzel!
Bagi
Bagi
- Bitmanipulátor
Szövegek kezelése Arduino C-ben
Ismét elakadtam. A Ruzsinszky féle C/C++ Arduino platformon könyvet olvasgatom. Sajnos az objektumorientált programozásról írtakat csak részben értem, és talán ezért nem boldogulok. A feladatom az lenne, hogy egy számot karakter stringé alakítsak, és ennk a stringnek megállapítsam a hosszát és egyenként elővegyem belőle a számjegyeket karakteres formában.
A változó deklaráció még megy (példa):
sz=123;
String karakter String(sz);
Azonban a karakter string hosszának megállapítása már nem:
hossz=karakter.lenght();
Jelenleg az UnoArduSim programot használom fejlesztésre. Lehet, hogy az nem boldogul ezzel a sorral. Esetleg valamilyen más ötlete tapasztalata nincs valakinek, hogy hogyan tudnám megoldani a problémámat?
Köszönettel
Bagi
sz=123;
Köszönettel
Bagi
Re: Arduino kezdő
És ha felbontod 10-es számrendszer szerint?
- Bitmanipulátor
Re: Arduino kezdő
Meg van a megoldás! Kiderült, hogy a fiam C++-ben nem teljesen kezdő, és kapásból elmondta mi a baj. Egyrészt volt egy betű csere amit nem vettem, észre lenght >> length.
Ami ennél fontosabb, hogy a működést is kezdem megérteni. Azoknak akiknek szüksége lehet ilyesmire leírnám a tapasztalataimat. Ime egy futó kód:
A kód annyit csinál, hogy meghívja a dblekerdez függvényt, aminek a millis() értékét adja át. A függvényben létrejön a string1 nevű string típusú változó. Még a deklarációs részben definiáltam egy szam_string nevű, string típusú változót, mert a stringgé alakított számot globálisan szeretném használni a programban. Mivel szükségem van a string hosszára és egy egy pozicióban található betűre is, ezért deklaráltam a hossz és betu nevű változókat. Ezek értékét a dblekerdez függvényben adom meg (a betu változóba a 0. pozíció karakterét másolom, nyilván itt egy változó áll majd egy hasznos kódban), de lehetne a loop()-ban is, csak ekkor hossz=szam_string.length(); és betu=szam_stringcharAt(x); kódot kellene írni, hiszen itt már csak a szam_string változóm létezik. A kódot az UnoArduSim nevű szimulátorban futtatom, ahol látom a változók értékét, és a dolog működik. Nyilván ez a kód alapjában egy marhaság, csak demonstrációs szándékkal adtam át a millis() értékét. Arra viszont jó volt, hogy kiderüljön csak int számokat tud karakterré alakítani, azt is előjelesen, tehát amíg a millis() által visszadott long érték alsó két byte-ja ~32000 alatt van, addig kapunk egy pozitiv számot reprezentáló stringet, viszont ezen érték felett minusz előjellel kezdődő stringet kapunk. Ez egyébként még hasznos is lehet. Nekem azonban így is tökéletes a működés.
Ha jól értettem meg a dolog lényegét, akkor a dblekerdez függvényemben létrejön egy string1 nevű objektumom, majd a függvényből kilépve ez meg is szűnik. Nem tudom memóriában mi történik, de remélem teljesen felszabadul a string1 számára lefoglalt memória. Futtattam a kódot a szimulátorban pár percig, az több ezer függvényhívás, és nem fogyott el a memória. Kipróbálom hamarosan valós hardveren is.
Bagi
String szam_string=String();
byte hossz=0;
char betu;
dblekerdez(millis());
void dblekerdez(int szam)
String string1=String(szam);
szam_string=string1;
hossz=string1.length();
betu=string1.charAt(0);
Bagi
Re: Arduino kezdő
Sajnos nekem valamiért nem tünik tökéletesnek ez a konvertálás rutin!
Meg hüjült 32762 után?
SorosMonitor:
32683
32690
32697
32704
32711
32718
32726
32733
32741
32748
32755
32762
4294934530 ????
4294934542
4294934554
4294934567
4294934580
4294934592
4294934604
4294934617
4294934629
4294934642
SorosMonitor:
32683
32690
32697
32704
32711
32718
32726
32733
32741
32748
32755
32762
4294934530 ????
4294934542
4294934554
4294934567
4294934580
4294934592
4294934604
4294934617
4294934629
4294934642
Re: Arduino kezdő
Talán igy már jó lessz:
byte hossz=0;
char betu;
Serial.println(szam_string);
void dblekerdez(unsigned long szam)
szam_string=String(szam);
betu=szam_string.charAt(0);
- Bitmanipulátor
ATmega328 lábkiosztás és pin megfeleltetés
Éppen hardvert építek. Az Arduino UNO R3 kapcsolási rajzából ki tudom logikázni, hogy melyik programban hivatkozott kivezetés melyik lábnak felel meg a mikrovezérlőben. Pl. A0 bemenet a 28PDIP chip 23-as lába. A programban azonban 14-es pin-re hivatkozok. Létezik valamilyen dokumentáció arra, hogy melyik chip-ben melyik láb felel meg a hivatkozott ki/bemenetnek? Találok valahol ilyet?
Köszönettel
Bagi
Köszönettel
Bagi
Re: Arduino kezdő
arduino.h állomány
Pighixxx oldalai/pdf/képei (látványos)
- Bitmanipulátor
Re: Arduino kezdő
Köszönöm!
Nos ezek azok az apró infók, amik egy kezdőnek nagyon hiányoznak. Már legalább egy órát vacakoltam, hogy kitaláljam, mit hová kell kötözgetni!
Bagi
Bagi
Re: Arduino kezdő
Off: Ezért újul/bővül meg a 60+16 napos tanfolyam, a csomagok, a cikkek egy része.
Ezen visszajelzések azok, amik segítenek tudni, hogy miket kell berelakni.
Most amivel bővül:
- Wiring és az Arduino története
- Arduino oldalágak, Wiring-húgok,
- Fritzing-tervezés,
- Processing kapcsolat
- Arduino lábak, és pillantás a fekete dobozba (regiszterek, belső chipszerkezet, Arduino "boncolás"
- LCD trükkök, adatgyűjtés....
És persze a tanfolyam tervezett kétirányú folytatása is tartogat meglepetéseket
Most amivel bővül:
- Bitmanipulátor
Re: Arduino kezdő
Nagyon jó! Köszönjük!
