ARDUINO 1.6.8
ARDUINO 1.6.8
HozzászólásSzerző: Robert » 2016. március 14. hétfő, 19:55
ARDUINO 1.6.8 - 2016.03.09
[ide]
* Added support for GUI interface scaling for UHD monitors.
Thanks to all contributors and testers:
https://github.com/arduino/Arduino/pull/4376
https://github.com/arduino/Arduino/pull/2776
* Editor position is saved when closing with Alt+F4 or clicking on the "X" button. Thanks @willie68
* Fixed a NullPointerException when dealing with some rare combination of package_*.json files
* Fixed incorrect key bindings handling for changing tab. Thanks @matthijskooijman
* MacOSX: Fixed handling of add indent/remove indent shortcuts (CMD+[ and CMD+])
* Fixed incorrect update of available libraries in Library Manager. Thanks @vicnevicne
* Serial plotter now correctly resize graphs with negative values. Thanks @vicnevicne
* Improved sketch preprocessor when handling C++11 keywords. Thanks @matthijskooijman @igrr
* Updates to keyword pigmentation to match Create
* Fixed display of LITERAL1 keywords
* Added target board information when "Error compiling" message is displayed. Thanks @PaulStoffregen
[core]
* avr: fixed USB_SendControl(...) for buffer with len > 64. Thanks @NicoHood
* avr: fixed yield() usage inside delay(). Thanks @vbextreme
* sam: fixed USB descriptor length
* avr: reduced boiler-plate for ISR declarations. Thanks @paulo-raca
* avr: added Timer3 support for atmega1284/1284p. Thanks @feilipu
* sam: added USB CDC send break support and readBreak API
[libraries]
* Added support for Arduino/Genuino 101 to: TFT, Ethernet, SD
* SD: the library is now board-agnostic. Thanks @feilipu
