soros port ékezetes betű kezelése
cree
Csatlakozott: 2016. február 14. vasárnap, 19:17
Hozzászólás Szerző: cree »
Soros port ékezetes betű kezelése vanak problémák !
unsigned char thisByte[] = {
  "ÁÉÍÓÖŐÚÜŰ"}; // text out
int i=0;
  //Initialize serial and wait for port to open:
  Serial.begin(115200);
  while (!Serial) {
    ; // wait for serial port to connect.
  // prints title with ending line break
  Serial.println("ASCII Table ~ Character Map");
  while (i<sizeof(thisByte))  {
    // prints value unaltered, i.e. the raw binary version of the
    // byte. The serial monitor interprets all bytes as
    // ASCII, so 33, the first number,  will show up as '!'
    Serial.write(thisByte[i]);
    Serial.print(", dec: ");
    // prints value as string as an ASCII-encoded decimal (base 10).
    // Decimal is the  default format for Serial.print() and Serial.println(),
    // so no modifier is needed:
    Serial.print(thisByte[i]);
    // But you can declare the modifier for decimal if you want to.
    //this also works if you uncomment it:
    // Serial.print(thisByte, DEC);
    Serial.print(", hex: ");
    // prints value as string in hexadecimal (base 16):
    Serial.print(thisByte[i], HEX);
    Serial.print(", oct: ");
    // prints value as string in octal (base 8);
    Serial.print(thisByte[i], OCT);
    Serial.print(", bin: ");
    // prints value as string in binary (base 2)
    // also prints ending line break:
    Serial.println(thisByte[i], BIN);
    delay(100);
    i++;
És amit vissza ad rossz!
Ă, dec: 195, hex: C3, oct: 303, bin: 11000011
�, dec: 129, hex: 81, oct: 201, bin: 10000001
‰, dec: 137, hex: 89, oct: 211, bin: 10001001
Ť, dec: 141, hex: 8D, oct: 215, bin: 10001101
“, dec: 147, hex: 93, oct: 223, bin: 10010011
–, dec: 150, hex: 96, oct: 226, bin: 10010110
Ĺ, dec: 197, hex: C5, oct: 305, bin: 11000101
�, dec: 144, hex: 90, oct: 220, bin: 10010000
š, dec: 154, hex: 9A, oct: 232, bin: 10011010
ś, dec: 156, hex: 9C, oct: 234, bin: 10011100
°, dec: 176, hex: B0, oct: 260, bin: 10110000
Miért is?
Re: soros port ékezetes betű kezelése
A kulcsszó: kódlap.
A kódlapokban ami a közös: 32..127 kódú karakterek. Az e felettiek eltérő módon vannak definiálva.
Neked sosem ékezetes betűd van. Hanem pl. 65-s DECimális értékű byte-d- És ez valahogyan megjelenik - a kódlaptól függően.
Te nem "Á" betűt küldesz be, hanem a 194-es kódot (1 byte, mely 194-et jelent)
Tippek, kódtáblák:
http://www.lookuptables.com/ebcdic_scancodes.php
http://www.asciitable.com/
Használd inkább ezt a kód táblát:
http://www.ascii-code.com
  193, 201, 205, 211, 214, 218, 220, 219};
 // "ÁÉÍÓÖŐÚÜŰ"}; // text out
Á, dec: 193, hex: C1, oct: 301, bin: 11000001
É, dec: 201, hex: C9, oct: 311, bin: 11001001
Í, dec: 205, hex: CD, oct: 315, bin: 11001101
Ó, dec: 211, hex: D3, oct: 323, bin: 11010011
Ö, dec: 214, hex: D6, oct: 326, bin: 11010110
Ú, dec: 218, hex: DA, oct: 332, bin: 11011010
Ü, dec: 220, hex: DC, oct: 334, bin: 11011100
Ű, dec: 219, hex: DB, oct: 333, bin: 11011011
cree
Köszönöm a megoldást! :)
// Még jobb ha Serial Monitoron 1* bekéred az ékezetes karaktereket!
unsigned char thisByte[17];
 //= {"ÁÉÍÓÖŐÚÜŰáéíóőóüű"}; // text out
int i=0;
  while (!Serial) {
  Serial.println("Soros Monitor.");
  Serial.println("Kerek 17 ekezetes betut ?");
  for(i=0; i<17; i++){
    Serial.print("? ");
    while(Serial.available() == 0) {}      //  Vár 1 PC billentyűnyomásra + Enter
    thisByte[i] = Serial.read();
    Serial.print((String)thisByte[i]);  //  Visszaírja a PCn beírt KARAKTERT a monitorra
    Serial.print(", DEC = ");  //  Visszaírja a PCn beírt KARAKTER kódját
    Serial.print((uint8_t)thisByte[i], DEC);
    Serial.print(", HEX = ");
    Serial.println((uint8_t)thisByte[i], HEX);
    i++;
  i=0;
    delay(100);
    i++;
cree
int i=0;
  while (!Serial) {
    Serial.print("? ");
    i++;
  i=0;
    delay(100);
    i++;
int változoba fix ékezetes szó amit megtudok hivni csak serial printin alat?
Serial.println(homerseglet);
ilyenre gondolok;
int homerseglet = {Hőmérséglet};
cree
    unsigned char thisByte1[] =
    {72, 245, 109, 233, 114, 115, 233, 103, 108, 101, 116};  //Hőmérséglet
    int i=0;
      while (!Serial) {
      while (i<sizeof(thisByte1))  {
        Serial.write(thisByte1[i]);
        Serial.print(thisByte1[i]);
        delay(100);
        i++;
serial porton igy jelenik meg sajnos....
H72ő245m109é233r114s115é233g103l108e101t116
Nézdmeg a minta kódomat!
cree
kapu48 írta:Nézdmeg a minta kódomat!
Végredmény még mindig ugyan az!
Serial.print((String)thisByte1);
Ez mért van benne?:
Serial.write(thisByte1); Ki íratod szám formályában ís?
cree
kapu48 írta:Ez mért van benne?:
Nekem csak ékezetes ascii kell megjelenités soros porton!
Sajnos van más probléma is hiába minden ez csak pc soros porton müködnek az ékezetes megjelenités bármilyen soredbe is !:(
Az ujabb ékezetes kitöltések helyén kérdöjelek vanak bluetools soros portos küldés hc-05 allat mindhiába ez az ékezetes nyüglödés!
BTserial.println(thisByte1);
végeredmény
H72?245m109?233r114s115?233g103l108e101t116
Kódtábla lehet ASCII mellett UTF-8 is! :)
Amíg nem azonos a küldő és a vevő oldalt a kódtábla - ezeket látod.
A HC-05/06 az a bejövő karaktert küldi át. Az Android UTF-8 formában kezeli/várja az ékezetes karaktert.... Ha úgy állítod be...
        Serial.print((String)thisByte1[i]);
        i++;
   Serial.println();
   i=0;
       BTserial.print((String)thisByte1[i]);
        i++;
cree
        i++;
   Serial.println();
   i=0;
        i++;
  #include <SoftwareSerial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
        int i=0;
          BTserial.begin(115200);
          while (!Serial) {
        i++;
   Serial.println();
   i=0;
        i++;
Még mindig probléma dec kirás megjelenik!
H72
ő245
m109
é233
r114
s115
é233
g103
l108
e101
t116
cree
Robert írta:Kódtábla lehet ASCII mellett UTF-8 is! :)
Igen erre gondoltam is!
De milyen apk bluetools terminal ba lehet ezt álitani karakter tipust?
Nagyon sok apkt kiprobaltam android alat bluetools terminalt egyik sem tutja kezelni ezt a hibát!
Érdekes BT terminal windows 8 mobile alat ok az ékezet kezelés.....
