Az eredeti C program:
Ebből a Sound rész nem kel, csak a DataFlash kezelése.
* Atmel Corporation
* File : sound_system2.c
* Compiler : IAR EWAAVR 3.20C
* Revision : $Revision: 1.4 $
* Date : $Date: Monday, November 15, 2004 12:53:58 UTC $
* Support mail : avr@atmel.com
* Supported devices : ATmega8535
* AppNote : AVR335 Digital Sound Recorder.
#include <inavr.h>
#include <ioavr.h>
#include "dataflash.h"
// prototypes
void setup (void);
void erasing (void);
void recording (void);
void write_to_flash (unsigned char ad_data);
void playback (void);
void next_page_to_next_buffer (unsigned char active_buffer, unsigned int page_counter);
void active_buffer_to_speaker (unsigned char active_buffer);
void write_SPI(unsigned char data);
// global variables
volatile unsigned char wait = 0;
void setup(void)
DDRB = 0xBD; // SPI Port initialisation
// SCK, MISO, MOSI, CS, LED, WP , RDYBSY, RST
// PB7, PB6, PB5, PB4, PB3, PB2 , PB1, PB0
// O I O O O O I O
// 1 0 1 1 1 1 0 1
PORTB = 0xFF; // all outputs high, inputs have pullups (LED is off)
DDRA = 0x00; // define port A as an input
PORTA = 0x00;
DDRD = 0x10; // define port D as an input (D4: output)
__enable_interrupt(); // enable interrupts
SPDR = data;
while (!(SPSR & 0x80)); // wait for data transfer to be completed
void erasing(void)
unsigned int block_counter = 0;
ACSR |= CLEARED; // set signal flag that new data has to be recorded next
// interrupt disabled, SPI port enabled, master mode, MSB first, SPI mode 3, Fcl/4
SPCR = 0x5C;
while (block_counter < 512)
PORTB &= ~DF_CHIP_SELECT; // enable DataFlash
write_SPI(BLOCK_ERASE);
write_SPI((char)(block_counter>>3));
write_SPI((char)(block_counter<<5));
write_SPI(0x00);
PORTB |= DF_CHIP_SELECT; // disable DataFlash
block_counter++;
while(!(PINB & 0x02)); // wait until block is erased
SPCR = 0x00; //disable SPI
void recording(void)
unsigned char count;
SPCR = 0x5C;
ADMUX = 0x00; // A/D converter input pin number = 0
ADCSRA = 0xD5; // single A/D conversion, fCK/32, conversion now started
do
do
} while(!(ADCSRA&(1<<ADIF))); // Wait for A/D conversion to finish
count = 6;
do // Customize this loop to 66 cycles !!
} while(--count); // wait some cycles
ADCSRA |= 0x40; // start new A/D conversion
write_to_flash(ADC-0x1D5); // read data, convert to 8 bit and store in flash
} while (!(PIND & 2)); // loop while button for recording (button 1) is pressed
ADCSRA = 0x00; // disable AD converter
SPCR = 0x00; // disable SPI
void write_to_flash(unsigned char flash_data)
static unsigned int buffer_counter;
static unsigned int page_counter;
if((ACSR&CLEARED)) // if flag is set that new data has to be written
buffer_counter = 0;
page_counter = 0; // reset the counter if new data has to be written
ACSR &= (~CLEARED); // clear the signal flag
while(!(PINB & 0x02)); // check if flash is busy
write_SPI(BUFFER_1_WRITE);
write_SPI(0x00); // don't cares
write_SPI((char)(buffer_counter>>8)); // don't cares plus first two bits of buffer address
write_SPI((char)buffer_counter); // buffer address (max. 2^8 = 256 pages)
write_SPI(flash_data); // write data into SPI Data Register
buffer_counter++;
if (buffer_counter > 528) // if buffer full write buffer into memory page
buffer_counter = 0;
if (page_counter < 4096) // if memory is not full
write_SPI(B1_TO_MM_PAGE_PROG_WITHOUT_ERASE);// write data from buffer1 to page
write_SPI((char)(page_counter>>6));
write_SPI((char)(page_counter<<2));
page_counter++;
PORTB |= 0x08; // turn LED off
while (!(PIND & 2)); // wait until button for recording (button 1) is released
void playback(void)
unsigned int page_counter = 0;
unsigned char active_buffer = 1; // active buffer = buffer1
TCCR1A = 0x21; // 8 bit PWM, using COM1B
TCNT1 = 0x00; // set counter1 to zero
TIFR = 0x04; // clear counter1 overflow flag
TIMSK = 0x04; // enable counter1 overflow interrupt
TCCR1B = 0x01; // counter1 clock prescale = 1
OCR1B = 0x00; // set output compare register B to zero
SPCR = 0x5C;
next_page_to_next_buffer (active_buffer, page_counter); // read page0 to buffer1
while (!(PINB & 0x02)); // wait until page0 to buffer1 transaction is finished
while ((page_counter < 4095)&(!(PIND & 4))) // while button for playback (button 2) is pressed
page_counter++; // now take next page
active_buffer_to_speaker (active_buffer);
if (active_buffer == 1) // if buffer1 is the active buffer
active_buffer++; // set buffer2 as active buffer
else // else
active_buffer--; // set buffer1 as active buffer
TIMSK = 0x00; // disable all interrupts
TCCR1B = 0x00; // stop counter1
while(!(PINB & 0x02)); // wait until flash is not busy
write_SPI(MM_PAGE_TO_B2_XFER); // transfer next page to buffer2
else // else
write_SPI(MM_PAGE_TO_B2_XFER); // transfer next page to buffer1
write_SPI((char)(page_counter >> 6));
write_SPI((char)(page_counter << 2));
write_SPI(0x00);
PORTB |= DF_CHIP_SELECT; // disable DataFlash and start transaction
#pragma vector = TIMER1_OVF_vect
__interrupt void out_now(void)
ACSR |= T1_OVF; // an interrupt has occured
// until active buffer not empty read active buffer to speaker
unsigned int buffer_counter = 528;
write_SPI(BUFFER_1_READ); // read from buffer1
else // else
write_SPI(BUFFER_2_READ); // read from buffer2
write_SPI(0x00); // write don't care byte
write_SPI(0x00); // start at buffer address 0
do
write_SPI(0xFF); // write dummy value to start register shift
while(!(ACSR&T1_OVF)); // wait for timer1 overflow interrupt
OCR1B = SPDR; // play data from shift register
ACSR &= (~T1_OVF); // clear the signal flag
} while (--buffer_counter);
void main(void)
setup();
for(;;)
if (!(PIND & 2)) // if button for recording (button 2) is pressed
PORTB &= 0xF7; // turn LED on
recording();
if (!(PIND & 1)) // if button for erasing (button 0) is pressed
erasing();
while (!(PIND & 1)); // wait until button for erasing (button 0) is released
if (!(PIND & 4)) // if button for playback (button 3) is pressed
playback();
while (!(PIND & 4)); // wait until button for playback (button 3) is released
PORTB |= 0x08; // turn LED off while running idle
Kb. 20%-nál tartok. Kérdés menyi + idő lesz a hibakeresés?
