webszerver paraméter átadás
dckillman
Csatlakozott: 2013. október 7. hétfő, 11:23
Hozzászólás Szerző: dckillman »
Lenne még egy kérdésem amivel borzolom ismét a kedélyeket :-)
Szóval van itt ez a kód:
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10, 0, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
String HTTP_req;          // stores the HTTP request
boolean LED_status = 0;   // state of LED, off by default
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    Serial.begin(9600);       // for diagnostics
    pinMode(2, OUTPUT);       // LED on pin 2
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                HTTP_req += c;  // save the HTTP request 1 char at a time
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    client.println("HTTP/1.1 200 OK");
                    client.println("Content-Type: text/html");
                    client.println("Connection: close");
                    client.println();
                    // send web page
                    client.println("<!DOCTYPE html>");
                    client.println("<html>");
                    client.println("<head>");
                    client.println("<title>Arduino LED Control</title>");
                    client.println("</head>");
                    client.println("<body>");
                    client.println("<h1>LED</h1>");
                    client.println("<p>Click to switch LED on and off.</p>");
                    client.println("<form method=\"get\">");
                    ProcessCheckbox(client);
                    client.println("</form>");
                    client.println("</body>");
                    client.println("</html>");
                    Serial.print(HTTP_req);
                    HTTP_req = "";    // finished with request, empty string
                    break;
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// switch LED and send back HTML for LED checkbox
void ProcessCheckbox(EthernetClient cl)
    if (HTTP_req.indexOf("LED2=2") > -1) {  // see if checkbox was clicked
        // the checkbox was clicked, toggle the LED
        if (LED_status) {
            LED_status = 0;
        else {
            LED_status = 1;
    if (LED_status) {    // switch LED on
        digitalWrite(2, HIGH);
        // checkbox is checked
        cl.println("<input type=\"checkbox\" name=\"LED2\" value=\"2\" \
        onclick=\"submit();\" checked>LED2");
    else {              // switch LED off
        digitalWrite(2, LOW);
        // checkbox is unchecked
        onclick=\"submit();\">LED2");
Szeretnék belőle csinálni egy külön funkciót az egész szerverből amit majd meghívok a loop-ból.Mikor ide ér a végrahajtás akkor pedig szeretném ha egy változót beállítaná a pl web=1 re.amit később főprogramből szeretnék elérni és ott műveletet végrehajtani és a végén nullázni a változót.
        if (LED_status) {
            LED_status = 0;
Sajnos nem tudom hogy hogyan kellene megoldani.
Köszönöm a segítséget
Re: webszerver paraméter átadás
Az átállításra két mód van:
- weblapot frissítesz (Head + meta refresh)
- ajax-ba beleásod magad. Az a szerver oldali push-t támogatja...
Az első egyszerűbbnek tűnik...
Itt azonban minden pl. 5 sec-ben frissül a HTML kódod, azaz ennyi a timeout...
dckillman
Szóval webszervert szeretném megcsinálni külön fgv-nek és a loopból meghívni.Ha pedig a webszerver adott helyre jut akkor pedig egy változó létrehoznék, amit a főprogramban tudnék használni(ha használtam akkor pedig nullázni,hogy a következő gombnyomás is el tudjam tárolni)
void webserver(??????){
//ha idáig eljutottam akkoritt
webinput=1;  /// ????
webserver();
//itt hogyan tudom az előzőleg létrehozott web változót használni
