Eladó LPC1768 fejlesztői panel
Apróhirdetés az oldalon a megunt, kinőtt holmikhoz. Kereskedelmi mennyiségek nem engedélyezettek.
Beregnand
Csatlakozott: 2013. december 19. csütörtök, 13:10
Hozzászólás Szerző: Beregnand »
Kép
Kép
Paraméterei:
ARM Cortex-M3 processor, running at frequencies of up to 100 MHz
ARM Cortex-M3 built-in Nested Vectored Interrupt Controller (NVIC)
Up to 512 kB on-chip flash programming memory
Up to 64 kB On-chip SRAM
In-System Programming (ISP) and In-Application Programming (IAP)
Eight channel General Purpose DMA controller (GPDMA)
Ethernet MAC with RMII interface and dedicated DMA controller
USB 2.0 full-speed device/Host/OTG controller
Four UARTs with fractional baud rate generation, internal FIFO, and DMA support
CAN 2.0B controller with two channels
SPI controller with synchronous, serial, full duplex communication
Two SSP controllers with FIFO and multi-protocol capabilities
Three enhanced I2C bus interfaces
I2S (Inter-IC Sound) interface
70 General Purpose I/O (GPIO) pins with configurable pull-up/down resistors
12-bit/8-ch Analog/Digital Converter (ADC) with conversion rates up to 200 kHz
10-bit Digital/Analog Converter (DAC) with dedicated conversion timer and DMA
Four general purpose timers/counters
One motor control PWM with support for three-phase motor control
Quadrature encoder interface that can monitor one external quadrature encoder
One standard PWM/timer block with external count input
Low power RTC with a separate power domain and dedicated oscillator
WatchDog Timer (WDT)
ARM Cortex-M3 system tick timer, including an external clock input option
Repetitive interrupt timer provides programmable and repeating timed interrupts
Each peripheral has its own clock divider for further power savings
Standard JTAG test/debug interface for compatibility with existing tools
Integrated PMU (Power Management Unit)
Four reduced power modes: Sleep, Deep-sleep, Power-down, and Deep power-down
Single 3.3 V power supply (2.4 V to 3.6 V)
Four external interrupt inputs configurable as edge/level sensitive
Non-maskable Interrupt (NMI) input
Wake-up Interrupt Controller (WIC)
Processor wake-up from Power-down mode via any interrupt
Brownout detect with separate threshold for interrupt and forced reset
Power-On Reset (POR)
Crystal oscillator with an operating range of 1 MHz to 25 MHz
4 MHz internal RC oscillator trimmed to 1 % accuracy
Code Read Protection (CRP) with different security levels
Unique device serial number for identification purposes
Bővebb információk:
http://www.is.gd/Z2zy3E
http://www.is.gd/xHdOPK
http://www.is.gd/sQMqhn
Ára: 10.000Ft + posta (egyeztetni a küldés típusát), érdeklődni az othertoolsKUKACfreemail.hu címen lehet.
Üdv.: beregna...
Re: Eladó LPC1768 fejlesztői panel
Első hozzászólással hirdetés? Csak nem Arduino fele lesz a csere ?:)
Igen, érdekes a helyzet Arduino körül, mert nem mindig a nagyobb teljesítmény a jobb.
A 328P-s Arduino előnye, hogy DIP-es, ki lehet vágni a kukába az egyébként is strapabíró IC-t és újat rakni helyette. Az SMD sajnos nem ugyanez, nano alatt nem is vagyok annyira bátor. Ha véletlen szétbarmolnám, akkor lehet, hogy egy UNO-t átépítek breadboard kompatibilissé, magas tüskesort rakok hüvelysáv helyett.
A Due nagy problémája, hogy 3.3V-on megy, kicsit drágább a mezei Arduinonál, de abban az árkategóriában már Raspberry Pi-t kapni, ami ugye sokkal húzósabb, mint a Due.
Az, hogy mit lehet kezdeni 53 IO-porttal még mindig kérdéses, mert a 21 is bőven elég. Ritkán kell több, arra meg van shift register.
A 328P az, amelyiknek éppen elég portja, ha 50.000 portja lenne sem lennék boldogabb, csak bogarászhatnám egyesével, hogy melyik-melyik.
Az Arduino UNO/R3 barkácsolásra kifogástalan. Talán egy kicsit több memória, meg 50 MHz belül jobb lenne, de így is oké.
UNO aljára a hosszútüskét felforrasztani? Csak a 10/16-os osztás macera..... :(
Vagy szalagkábel? tüskesorral megfejelve?
A rögzítés a fontos, hogy ne lógjon. A hüvelysávba be lehet dugni a breadboardos kábeleket és érintkeznek.
Beregnand
Sziasztok, bocsánat, távol voltam.
Arduino-m már van, nagyon rugalmas dolog. Ezt a panel egy speciális projekthez kellet volna, de az meghiúsult, így az LPC eladó sorba került.
