Rendetlenkedő programok
saua
Csatlakozott: 2015. április 17. péntek, 16:39
Hozzászólás Szerző: saua »
Sziasztok
Egy termosztát programmal kísérletezgetek. A program működését csak nagyjából értem.
#include <EEPROM.h>
 #include <LiquidCrystal.h>// include the library code
#include <OneWire.h>
// Data wire is plugged into pin 6 on the Arduino
#define ONE_WIRE_BUS 6
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
 int led =9; // led is at pin
 int temp;  // make a variable called temp
 int settemp; // make a variable called temp
 int swtu = 7;  // switch up is at pin 7
 int swtd = 8;   // switch down is at pin 8
 LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // lcd is at 12,11,5,4,3,2
   pinMode (led,1);  // make led or pin13 an output
   lcd.begin(16, 2); // set up all the "blocks" on the display
   lcd.setCursor(0,0); // set the cursor to colum 0 row 0
   lcd.print("Temp:");
   lcd.setCursor(12,0);
   lcd.print((char)223);
   lcd.setCursor(13,0);
   lcd.print("C");
   EEPROM.read (1); // make the eeprom or atmega328 memory address 1
sensors.requestTemperatures();   // beolvas a DS18B20- tol
   int temp = sensors.getTempCByIndex(0);
   lcd.setCursor (9,0);
   lcd.print (temp);  // Print the current temp
      settemp = EEPROM.read(1); // read the settemp on the eeprom
   delay (250); // wait for the lcd to refresh every 250 milliseconds
   if             // if we se the switch up pin reading on 1 or 5 volts
     (digitalRead(swtu)== 1 )
     settemp ++  // add one to the settemp, the settemp is the ideal temperature for you
 else{// other wise do nothing
 if
 (digitalRead (swtd) == 1)// if we detect a 1 on the other switch pin
   (settemp --);// subtract one fromm the settemp
 else {
 // else, do nothing
 if (temp > settemp) // if the temperature exceeds your chosen settemp
   digitalWrite (led, 1); // turn on the led
 else // if that doesn't happen, then turn the led off
   digitalWrite (led,0);
 lcd.setCursor (0,1); // set the cursor to 0,1
 lcd.print ("Set to:"); // Print set to and your ideal temperature in f
  lcd.setCursor (9,1);
 lcd.print (settemp);
 lcd.setCursor(12,1);
   lcd.setCursor(13,1);
   lcd.print("C");
 EEPROM.write (1,settemp); /* write the most recent settemp in eeprom data stoage
   so that if the power is disconnected, you settemp is saved!*/
 delay (250); // wait 250 milliseconds
 } // we're done
Az egyik probléma, hogy bekapcsoláskor a kijelzőn egy pillanatra megjelenik a 85 fok, és a kimenetre ekkor logikai „1” kerül ami nagyon zavaró, hogy lehetne eltüntetni? a loop() a szenzor lekérdezésével kezdődik az első adat meg minden bekapcsoláskor a 85 fok.
Egy másik probléma, hogy az alaplapon levő13-as LED állandóan ég, fogalmam sincs miért.
A program eredetije itt található http://www.instructables.com/id/Arduino ... /?ALLSTEPS , ebbe piszkáltam bele, hogy tudjam használni a DS18B20 –al.
saua
Re: Rendetlenkedő programok
a másik fórumban kaptam választ, köszi.
"Először konverzió, utána hőfokkiolvasás...."
úgy látom, csak ez a két sor tartozik a szenzorhoz:
ha ezt a két sort megcserélem nem változik semmi.
A függvénykönyvtáradban így van belül megírva. először kiolvas, utána konvertál.
Tedd a setup részbe az első kiolvasást.... Azt úgyse íratod ki :)
saua
Köszi a választ
Csak úgy sikerült megoldani a problémát ha a kiolvasást, a konvertálást és még egy 1000 ms -os késleltetést is beírtam a setup részbe.
A libraryban a menetrend:
- kiolvasás
- mérés/konverzió indítása
Az hogy 1000 ms várakozást tettél be: a hőmérőid parazita módban vannak használva (tipp :))
