Arduino 1.6.6
Arduino 1.6.6
ARDUINO 1.6.6 - 2015.11.03
[ide]
* Switched to Java 8, which is now both bundled and needed for compiling the IDE
* Added link to unofficial boards support list in preferences
* Limit of possible new sketches in a day raised to 676. Thanks @Chris--A
* Windows: fixed a bug when running username had non ASCII chars
* Lots of fixes
* ArduinoISP examples moved under 11.ArduinoISP folder
* MacOSX: binary is now able to tell the IDE its current working directory. Eases life to those using the IDE from the CLI
* CLI: if specified board doesn't exist, fail instead of using a default one
* Windows: IDE stores its stuff under %LOCALAPPDATA% instead of %APPDATA% (which was a roaming folder). %APPDATA% content is automatically migrated to new location
* Added 74880 baud rate to serial monitor. Thanks @Chris--A
* When changing tab, file name is shown in window title
* IDE groups compiled files into "libraries", "core" and "sketch" folders
* Added Serial Plotter. Thanks @henningpohl
* Editor: triple click selects whole line
* Windows: IDE startup feels faster
* Examples of libraries with a .development flag file in their root folder won't get marked as read-only. See #2619
* Update notifications: when updates are available from either Library or Boards Managers, a popup will be shown
* Introducing arduino-builder, a command line tool that properly calls gcc. Fixes lots of issues about buggy preprocessing.
* Each open sketch gets built in its own folder, allowing the IDE to recycle previous compilations and being much faster
* "Go to line": CTRL+L or Edit > Go to line... will open a dialog where you can type the line number where you want the editor to jump to
* Added boards.local.txt support: like platform.local.txt, allows to enrich a boards.txt definition without modifying the original file. Thanks @Wackerbarth
* Library to library dependencies: when your sketch imports a library, and that library uses another, the IDE will find out without you having to add a useless #include to your sketch
* Allow per-platform keywords.txt. Thanks @PaulStoffregen
* Allow spaces in IDE install path on Linux. Thanks @matthijskooijman
* Fixed a lot of documentation. Thanks to @per1234 @q2dg
* Fixed parsing for SystemProfiler when scanning for available serial ports on Macosx El Capitan
[libraries]
* Bridge: YunClient.connected() returns true if there are bytes available for read. Thanks @RobAtticus
* Bridge: YunClient.stop() now empties all buffers. Thanks @RobAtticus
* Ethernet: Added missing keywords. Thanks @per1234
* Ethernet: Fixed DNSClient.inet_aton() function. Thanks @jhorck
* Ethernet: Expose optional DHCP timout parameters to Ethernet:begin(). Thanks @chaveiro
* Wire: Implemented Wire.end().
* Wire: Fixed bug with repeated START for AVR. Thanks Nate Williams
* Wire: Resolved timing issues on AVR. See #2173 #1477.
* Wire: Fixed bug in repeated start in slave mode on SAM. See #3908
* SD: Change "char *" to "const char *" on methods accepting a string as a parameter. Thanks @Ivan-Perez
* Scheduler: Added support for cortex-M0. Thanks @PeterVH
[core]
* Added new PluggableUSB and HID support. This change introduces a more powerful API for
libraries that wants use advanced features of USB-Device.
Thanks to @obra @NicoHood @matthijskooijman @nospam2000 @weizenspreu
* AVR: fixed wrong turnOffPWM() for TIMER0B. Thanks @gonzoveliki
* AVR: added support for AtmegaXXu2. Thanks @NicoHood
* AVR: a bunch of USB Core bug fix. Thanks @NicoHood
* AVR: Expose serial setting from USB-CDC serial port. Thanks @matthijskooijman
* ArduinoISP is now compatible with every architecture (not only AVR) and is much more stable. Thanks @PeterVH
* Print not aborting on write() failure. Thanks @stickbreaker
* AVR: Faster interrupts patch. Thanks @xxxajk
* AVR: Fixed pulseInLong wrong measurements.
* AVR: Removed a bunch of compiler warnings. Thanks @NicoHood
* Improved variants files for Boards Gemma and Ethernet
csegebiga
Re: Arduino 1.6.6
úgy tűnik öngólt lőttem:
feltettem ezt a verziót a gépemre, és az eddig a LiquidCrystal_I2C2004V1.zip libbel működő lcd kijelzés megborult.
a serialmonitor példaprogram hibátlanul fut, abban lévő lcd.write() működik rendesen, tele is írhatom vele a kijelzőt.
ámde a lcd.print() nem dolgozik jól. a betűket nem írja, a számokat össze-vissza rövidíti. nem megy rendesen.
bekapcsolva a verbose logot a fordításnál az alábbi hibajelzés látható:
C:\Users\(c)csege\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:80:16: error: conflicting return type specified for 'virtual void LiquidCrystal_I2C::write(uint8_t)'
   virtual void write(uint8_t);
In file included from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
                 from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
                 from C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:224,
                 from C:\Users\(c)csege\AppData\Local\Temp\build939e6c1319634d5b6603d8a131c4541a.tmp\sketch\HelloWorld.pde.cpp:1:
C:\Program Files\Arduino\hardware\arduino\avr\cores\arduino/Print.h:48:20: error:   overriding 'virtual size_t Print::write(uint8_t)'
     virtual size_t write(uint8_t) = 0;
Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Using library LiquidCrystal_I2C in folder: C:\Users\(c)csege\Documents\Arduino\libraries\LiquidCrystal_I2C (legacy)
exit status 1
Hiba fordításkor.
ez a print.h és print.cpp az arduino ide, és nem a liquidcrystal_i2c része.
neten rákeresve az "overriding 'virtual size_t Print::write(uint8_t)' virtual size_t write(uint8_t) = 0;" kifejezésre, láttam, hogy a jelenség nem ismeretlen, és nem is újkeletű.
de a megoldásra még nem leltem rá.
kipróbáltam 6 féle i2c lcd libraryt, és mindegyikkel ez a hibajelenség jött elő.
közben lecseréltem az 1.6.6 rendszert az 1.6.7 re, de a jelenség ugyanaz.
van valami ötletetek, hogy hogyan orvosolható ez a hiba?
thx4all!
(c)
Re: Arduino 1.6.6
Downgrade 1.6-5-re?
Re: Arduino 1.6.6
Esetleg ezt kipróbálni:
Arduino_liquidcrystal.zip
Re: Arduino 1.6.6
Frissebb kiadás az i2c/LCD kezelésre: https://bitbucket.org/fmalpartida/new-l ... /wiki/Home
csegebiga
Re: Arduino 1.6.6
köszönöm, megnézem!
(c)
