Adafruit+ST7735+UNO karakterek hasznalata
supercharger
Csatlakozott: 2020. február 6. csütörtök, 20:08
Hozzászólás Szerző: supercharger »
Kezdo vagyok a legkezdobbek kozul :)
Van egy olyan problemam, hogy ha nem az alap karakter keszletet hasznalom akkor nem frissul az ertek az TFT-n hanem rairja magat az elozo ertekre.
Segitseget megkoszonom :)
// begin
#include <Adafruit_GFX.h>      // include Adafruit graphics library
#include <Adafruit_ST7735.h>   // include Adafruit ST7735 TFT library
#include <DHT.h>               // include DHT library
#include <Fonts/FreeMonoBoldOblique24pt7b.h>
// define pins nano uno
#define TFT_RST   8           // TFT RST pin is connected to arduino pin 8
#define TFT_CS    9           // TFT CS  pin is connected to arduino pin 9
#define TFT_DC    10          // TFT DC/A0  pin is connected to arduino pin 10
// TFT SCK  pin is connected to arduino pin 13
// TFT SDA  pin is connected to arduino pin 11
// define ledPins
#define ledPin    A1
#define ledPinN   A2
#define ledPinC   A3
#define BLACK 0x0000
#define WHITE 0xFFFF
#define RED   0xF800
#define BLUE  0x001F
#define ORANGE  0xff8000
// initialize ST7735 TFT library
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
#define DHTPIN  A0           // DHT11 data pin is connected to Arduino analog pin 1
#define DHTTYPE DHT11        // DHT11 sensor is used
float temp; //Stores temperature value
DHT dht11(DHTPIN, DHTTYPE);  // initialize DHT library
void setup(void)
  pinMode(A1, OUTPUT);    // sets the digital pin A1 as output
  pinMode(A2, OUTPUT);    // sets the digital pin A2 as output
  pinMode(A3, OUTPUT);    // sets the digital pin A3 as output
  tft.initR(INITR_BLACKTAB);     // initialize a ST7735S chip, black tab
  tft.setRotation(3);
  tft.fillScreen(ST7735_BLACK);  // fill screen with black color
  tft.setCursor(57, 70);              // move cursor to position
  tft.print("");
  delay(5000);
  tft.drawRoundRect(0, 0, 160, 128, 6, ST7735_WHITE);   // draw circle
  tft.setTextSize(2);                 // text size = 1
  tft.setTextColor(ST7735_RED, ST7735_BLACK);     // set text color to green and black background
  tft.setCursor(35, 9);              // move cursor to position
  tft.print("TEMP");
  tft.setTextSize(2);                 // text size = 2
  // initialize DHT11 sensor
  dht11.begin();
  // initialize serial communications:
char _buffer[7];
// main loop
  // read humidity
  byte humi = dht11.readHumidity();
  // read temperature
  byte temp = dht11.readTemperature();
  // print temperature (in °C)
  sprintf(_buffer, "%02u", temp);
  tft.setTextColor(ST7735_WHITE, ST7735_BLACK);  // set text color to red and black background
  tft.setFont(&FreeMonoBoldOblique24pt7b);
  tft.setTextSize(2);
  tft.setCursor(27, 98);
  tft.print(_buffer);
  tft.setFont();
  tft.setTextSize(1);
  tft.drawCircle(147, 93, 1, ST7735_WHITE);  // print degree symbol ( ° )
  tft.setCursor(149, 95);
  tft.print("C");
  delay(1000);    // wait a second
  // print humidity (in %)
  sprintf(_buffer, "%02u%%", humi);
  tft.setTextColor(ST7735_CYAN, ST7735_BLACK);  // set text color to cyan and black background
  tft.setTextSize(1);
  tft.setCursor(37, 116);
  tft.print(_buffer);
  tft.setCursor(7, 116);
  tft.print("H:");
  tft.setTextColor(ST7735_ORANGE, ST7735_BLACK);  // set text color to cyan and black background
  tft.setTextSize(1);
  tft.setCursor(83, 116);
  tft.print("E:");
  // if the analog value is high enough, turn on the LED:
  if (temp >= 33) {
    tft.setCursor(125, 116);
    tft.setTextSize(1);
    tft.setTextColor(ST7735_RED, ST7735_BLACK);  // set text color to red and black background
    tft.print("HOT");
    delay (1000);
    digitalWrite(ledPin, LOW);
    digitalWrite(ledPinN, HIGH);
    digitalWrite(ledPinC, HIGH);
  else if (temp < 27) {
    tft.setTextSize(1);
    tft.setTextColor(ST7735_BLUE, ST7735_BLACK);  // set text color to red and black background
    tft.print("COLD");
    delay (1000);
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPinC, LOW);
  else {
    tft.setTextSize(1);
    tft.setTextColor(ST7735_GREEN, ST7735_BLACK);  // set text color to red and black background
    tft.print("OK  ");
    delay (1000);
    digitalWrite(ledPinN, LOW);
  // print the analog value:
  Serial.println(_buffer);
  delay(1000);        // delay in between reads for stability
// end of code.
supercharger
Re: Adafruit+ST7735+UNO karakterek hasznalata
Csatoltam egy kepet a problemarol
Koszonon
Tipp: frissítés előtt kiíratsz 2 db szóközt?
Illetve a kiíratás esetén olyan hogy a régivel mit tegyen (OR/XOR) logika, vagy írja felül - nem állítható az inicializálás részben?
supercharger
Köszönöm az ötletet, próbálom
