Arduino - 1.8.11/1.8.12
HozzászólásSzerző: Robert » 2020. április 23. csütörtök, 15:44
ARDUINO 1.8.12 2020.02.13
[ide]
* Reverted the bundled Java JRE to the latest freely redistributable Oracle JRE for all
platforms except:
- macOS (due to notarization)
- aarch64 (due to missing graphical support)
Switching to AdoptJDK demonstrated to be more challenging than expected, bringing in
some corner case bugs that were not being caught by our testing procedures:
- https://github.com/arduino/Arduino/labels/OpenJDK
To guarantee the best user experience we decided to revert to the latest working JRE
until all the issues are resolved.
* Improved visualization of compiler errors (@matthijskooijman)
* Fixed: "Comparison method violates its original contract" error in library manager
* Serial monitor is no more cleared during upload, so it can be copy/pasted (@PaulStoffregen)
[arduino-builder]
* FIX REGRESSION: library priority selection for bundled libraries (like SD or Ethernet)
* FIX REGRESSION: use AVR core installed via Board Manager (when present) instead of the one bundled in the IDE
* Improved precompiled libraries handling
* FIX: paths with spaces are now correctly printed in compiler output
ARDUINO 1.8.11 2020.01.27
[ide]
* FIX: Serial plotter do not hang if empty lines are received
* A lot of accessibility improvements in Libs and Board managers GUI for screen readers (thanks @joew46167)
* Sligtly improved support for themes in Libs and Board managers (thanks @matthijskooijman)
* Serial plotter: added serial input text field (thanks @cactorium)
* MacOSX: support for notarization (thanks @PaulStoffregen for the support)
* Fix wrong bracket match rectangle on auto format (thanks @magedrifaat)
* Pluggable discoveries: runtime.platform.path and runtime.hardware.path are now available as variables (thanks @PaulStoffregen)
[arduino-builder]
* FIX: missed library-detection cache (forcing lib detection on each build)
* FIX: Windows: the build folder may reside on a different partition
* FIX: Segfault in arduino-builder with -dump-prefs if no sketch is specified
* FIX: Allow loading of global user-define platform.txt
* FIX: Fixed nil pointer exception on some rare case with multiple libs
* FIX: Print "multiple libraries found for header.h" message only when it really happens
* FIX: Fixed library priorities on some rare circumstances
[hardware]
* updated AVR core to 1.8.2
[wifi-updater]
* updated to 0.10.10
Vissza: “Bascom/Arduino/Wiring frissítések”
