Arduino 1.8.13...1.8.19
ARDUINO 1.8.19 2021.12.20 SECURITY HOTFIX RELEASE
[ide]
Removed log4j from IDE. Fix CVE-2021-45105, CVE-2021-45046
ARDUINO 1.8.18 2021.12.14 SECURITY HOTFIX RELEASE
[ide]
Upgrade log4j to 2.16.0 - Extra hardening for CVE-2021-44228
ARDUINO 1.8.17 (not released superseded by 1.8.18)
[ide]
Upgrade log4j to 2.15.0 - CVE-2021-44228 (thanks @rhowe)
ARDUINO 1.8.16 2021.09.06
[ide]
Removed the very outdated off-line documentation.
Do not crash if a malformed boards index URL is entered in preferences.
Fixed font-resizing problem with multiple tabs open.
Updated FTDI drivers to version 2.12.36.4
[wifi-firmware]
Added latest firmwares (up to version 1.4.8) for NINA-based boards
ARDUINO 1.8.15 2021.05.13
HOTFIX:
Fixed regression in library discovery (failing to compile bundled libs, like SD or Ethernet, on some platforms)
ARDUINO 1.8.14 2021.05.12
[ide]
Fix status bar custom board preferences disappearing (thanks @magedrifaat)
Boards Manager bugfix: sometimes the "Install" button appeared instead of "Update" after entering a search term.
Libraries/Boards Manager: the Type and Category filters are kept after install/uninstall.
Added 'deprecated' label support in Boards Manager, platforms marked as deprecated are shown at the bottom of the list.
Serial Plotter: line endings dropdown menu now comply with the global preference settings. (thanks @sceniclife)
Libraries Manager: Maintainer is displayed instead of the Author.
Firmware Updater: Added new firmwares and support for Nano RP2040 Connect.
Boards Manager: cached 3rd party package_index.json are no more deleted if the origin URL is removed from preferences, this allows other tools (like arduino-cli), that may have different URLs configuration, to work properly.
The board configuration submenus are now scrollable.
New shortcut: Shift+click on Serial Monitor button will open the Serial Plotter. (thanks @n-elia)
Fixed NPE if no board is selected. (thanks @matthijskooijman)
[arduino-builder]
Improved lib detection: check for matching name in library.properties
Fix compile if invalid build.options.json is found (thanks @d-a-v)
Improved error messages for .cpp/.h file in the sketch
ARDUINO 1.8.13 2020.06.16
[ide]
Fixed crash on MacOSX >=10.15 with multiple monitor setups.
The boards in the boards list in the "Tools" menu are now grouped by platform. This should make the selection easier when there are lots of boards loaded in the IDE. (thanks @matthijskooijman)
Fixed save of proxy username/password settings in "manual proxy" section.
In "Tools / Programmers" menu only shows programmers related to the currently selected board. (thanks @matthijskooijman)
Fixed: sketch window out-of-display if the IDE is restarted after removing an external monitor.
Allow baudrate/config change when the Serial Monitor/Plotter is disabled. (thanks @matthijskooijman)
Updated jmdns to 3.5.5. Should improve network board detection.
Optimized libraries scanning during startup. (thanks @ricardojlrufino)
Better vertical centering of file names in tabs. (thanks @ricardojlrufino)
Better console rendering of progress bar during upload. (thanks @matthijskooijman)
[arduino-builder]
FIX REGRESSION: Fixed precompiled libraries containing "wrapper" code that has to be compiled together with the precompiled part.
Removed automatic '--relax' for compiles on Atmega2560 MCU
Fixed skethbook+bootloader hex merger when the bootloader is in .bin format.
Fixed relative path errors when traversing different partitions (in particular on macosx for larger sketches)
Added #define variable during lib discovery phase
Improved progress report from compile
[core]
Updated AVR core to 1.8.3:
Wire class now supports timeout
Upgraded avr-gcc to 7.3.0-atmel3.6.1-arduino7
Re: Arduino 1.8.13...1.8.19
És magyarul:
ARDUINO 1.8.19 2021.12.20 BIZTONSÁGI HOTFIX KIADÁS
[ide]
A log4j eltávolítva az IDE-ből. CVE-2021-45105, CVE-2021-45046 javítása
ARDUINO 1.8.18 2021.12.14 BIZTONSÁGI HOTFIX KIADÁS
[ide]
A log4j frissítése 2.16.0-ra – Extra keményítés a CVE-2021-44228 számára
ARDUINO 1.8.17 (nem jelent meg, helyette az 1.8.18)
[ide]
A log4j frissítése 2.15.0-ra – CVE-2021-44228 (köszönet @rhowe)
[ide]
Eltávolította a nagyon elavult off-line dokumentációt.
Ne omoljon össze, ha rosszul formázott tábla index URL-t ad meg a beállításokban.
Javítva a betűméret-átméretezési probléma több megnyitott lap esetén.
FTDI illesztőprogramok frissítve a 2.12.36.4 verzióra
[wifi-firmware]
Hozzáadott legújabb firmware (1.4.8-as verzióig) a NINA-alapú kártyákhoz
HOTFIX:
Javítva a regresszió a könyvtárfelderítésben (egyes platformokon nem sikerült a kötegelt libs-eket, például az SD-t vagy az Ethernetet lefordítani)
[ide]
Javítsa ki az állapotsor egyéni tábla preferenciáinak eltűnését (köszönet @magedrifaat)
Boards Manager hibajavítás: néha a "Telepítés" gomb jelent meg a "Frissítés" helyett a keresőkifejezés beírása után.
Libraries/Boards Manager: a Típus és Kategória szűrők a telepítés/eltávolítás után megmaradnak.
Az „elavult” címke támogatása hozzáadva a Boards Managerben, az elavultként megjelölt platformok a lista alján jelennek meg.
Soros plotter: a sorvégek legördülő menüje mostantól megfelel a globális beállításoknak. (köszi @sceniclife)
Libraries Manager: A Szerző helyett a Karbantartó jelenik meg.
Firmware-frissítő: Új firmware-ek és támogatás a Nano RP2040 Connecthez.
Boards Manager: a gyorsítótárazott 3rd party package_index.json többé nem törlődik, ha az eredeti URL-t eltávolítják a beállítások közül, ez lehetővé teszi más eszközök (például az arduino-cli) megfelelő működését, amelyek eltérő URL-konfigurációval rendelkeznek.
A tábla konfigurációs almenüi most görgethetők.
Új parancsikon: Shift+kattintás a Soros monitor gombra a Serial Plotter megnyitásához. (köszi @n-elia)
Javított NPE, ha nincs kártya kiválasztva. (köszi @matthijskooijman)
[arduino-építő]
Továbbfejlesztett lib észlelés: ellenőrizze a megfelelő nevet a library.properties fájlban
Javítsa ki a fordítást, ha érvénytelen build.options.json fájlt talál (köszönet @dav)
Továbbfejlesztett hibaüzenetek a vázlatban szereplő .cpp/.h fájlhoz
[ide]
Javítva az összeomlás MacOSX >=10.15 rendszeren több monitor beállítással.
Az "Eszközök" menü tábláinak listájában a táblák mostantól platformok szerint vannak csoportosítva. Ez megkönnyíti a kiválasztást, ha sok kártya van betöltve az IDE-be. (köszi @matthijskooijman)
Javítva a proxy felhasználónév/jelszó beállításainak mentése a „kézi proxy” részben.
Az "Eszközök / Programozók" menüben csak az aktuálisan kiválasztott kártyához kapcsolódó programozók jelennek meg. (köszi @matthijskooijman)
Javítva: az ablak vázlatos megjelenítése, ha az IDE újraindul a külső monitor eltávolítása után.
Engedélyezze az átviteli sebesség/konfig módosítását, ha a soros monitor/plotter le van tiltva. (köszi @matthijskooijman)
A jmdns frissítve 3.5.5-re. Javítani kell a hálózati kártya észlelését.
Optimalizált könyvtárak vizsgálata indításkor. (köszönöm @ricardojlrufino)
A fájlnevek jobb függőleges központosítása a lapokon. (köszönöm @ricardojlrufino)
A folyamatjelző jobb konzolos megjelenítése feltöltés közben. (köszi @matthijskooijman)
[arduino-építő]
FIX REGRESSZIÓ: Javítva a "wrapper" kódot tartalmazó előre lefordított könyvtárak, amelyeket az előre lefordított résszel együtt kell lefordítani.
Az automatikus „--relax” eltávolítása az Atmega2560 MCU-n lévő fordításoknál
Javítva a skethbook+bootloader hexa összevonása, ha a rendszerbetöltő .bin formátumú.
Javítva a relatív elérési út hibák különböző partíciók bejárásakor (különösen macosx-en nagyobb vázlatokhoz)
#define változó hozzáadva a lib felfedezési fázisban
Javított előrehaladási jelentés az összeállításból
[mag]
Az AVR mag frissítve 1.8.3-ra:
A vezetékosztály mostantól támogatja az időtúllépést
Az avr-gcc frissítve 7.3.0-atmel3.6.1-arduino7-re
