I2C EEPROM kezelése
Memoria kezelés hogyan?
Ezt a rutint megváltoztattam:
Prog13:
Print "EEPROM"
   C = 0
   I2cstart                                                 ' Send I2C Start.
   I2cwbyte &B10100000                                      ' Select MicroChip EEPROM device type, address and write bit.
   I2cwbyte 0                                               ' Send high address to write to.
   I2cwbyte 0                                               ' Send low address to write to.
   A = &B10101010
   Print "Written:" ; A
   I2cwbyte &B10101010
                                 ' Send the data to be written.
   If Err = 0 Then                                          ' check status of operation.
      Print "OK."                                           ' Report success.
   Else                                                     ' or
      Print "Err."                                          ' Report failure.
   I2cstop                                                  ' All we want to do is done.
   I2crbyte C                                               ' Send the data to be written.
   Print "Read:" ; C
Igy:
Dim C As Byte 		 ’ felvettem C-t
Prog13:
Print "EEPROM"
   C = 0			’ C = 0
   I2cstart
   I2cwbyte &B10100000
   I2cwbyte 0
   I2cwbyte 0
   A = &B10101010
   I2cwbyte &B10101010
   If Err = 0 Then
      Print "OK."
   Else
      Print "Err."
   I2cstop
   I2cstart
   I2cwbyte &B10100000
   I2cwbyte 0
   I2cwbyte 0
   I2crbyte C             		 ’ C-be olvasom be, mert A-ban már eredetileg is benne van!
   Print "Read:" ; C   		’ IT 0-át IRKÍ!!!
   I2cstop
Akkor most az írás nem jó, vagy az olvasás???
Ennyi változtatás
   I2crbyte C ,  Nack    ' Read 255
   I2crbyte C ,  ack      ' Read 255
Mostnmár mintha az írás nem lenne jó![/code]
Ez van a helpben:
'name                     : i2c.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : demo: I2CSEND and I2CRECEIVE
'micro                    : Mega48
'suited for demo          : yes
'commercial addon needed  : no
$regfile = "m16def.dat"                                     ' specify the used micro
$crystal = 14746500                                         ' used crystal frequency
$baud = 9600                                                ' use baud rate
$hwstack = 128                                              ' default use 32 for the hardware stack
$swstack = 128                                              ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
'or use the TWI !
Config Scl = Portc.0
Config Sda = Portc.1
Declare Sub Write_eeprom(byval Adres As Byte , Byval Value As Byte)
Declare Sub Read_eeprom(byval Adres As Byte , Value As Byte)
Const Addressw = 174                                        'slave write address
Const Addressr = 175                                        'slave read address
Dim B1 As Byte , Adres As Byte , Valuew As Byte , Valuer As Byte       'dim byte
Valuew = 21
Valuer = 0
Call Write_eeprom(1 , Valuew) : Print "Write: 1: " ; Valuew 'write value of three to address 1 of EEPROM
Call Read_eeprom(1 , Valuer) : Print "Read: 1: " ; Valuer   'read it back
Call Read_eeprom(5 , Valuer) : Print "Read: 5: " ; Valuer   'again for address 5
'-------- now write to a PCF8474 I/O expander -------
I2csend &H40 , 255                                          'all outputs high
I2creceive &H40 , B1                                        'retrieve input
Print "Received data " ; B1                                 'print it
Rem Note That The Slaveaddress Is Adjusted Automaticly With I2csend & I2creceive
Rem This Means You Can Specify The Baseaddress Of The Chip.
'sample of writing a byte to EEPROM AT2404
    I2cstart                                                'start condition
    I2cwbyte Addressw                                       'slave address
    I2cwbyte Adres                                          'asdress of EEPROM
    I2cwbyte Value                                          'value to write
    I2cstop                                                 'stop condition
    Waitms 10                                               'wait for 10 milliseconds
End Sub
'sample of reading a byte from EEPROM AT2404
   I2cstart                                                 'generate start
   I2cwbyte Addressw                                        'slave adsress
   I2cwbyte Adres                                           'address of EEPROM
   I2cstart                                                 'repeated start
   I2cwbyte Addressr                                        'slave address (read)
   I2crbyte Value , Nack                                    'read byte
   I2cstop                                                  'generate stop
End Sub
' when you want to control a chip with a larger memory like the 24c64 it requires an additional byte
' to be sent (consult the datasheet):
' Wires from the I2C address that are not connected will default to 0 in most cases!
'   I2cstart                                                'start condition
'   I2cwbyte &B1010_0000                                    'slave address
'   I2cwbyte H                                              'high address
'   I2cwbyte L                                              'low address
'   I2cwbyte Value                                          'value to write
'   I2cstop                                                 'stop condition
'   Waitms 10
Az eredmény:
Write: 1: 21
Read: 1: 255
Read: 5: 255
Received data 255
Eeprom csere nem segítet!
Valami ötlet?
Ha kiveszem a Nack-ot akkor!
Az eredmény:
Write: 1: 21
Read: 1: 0
Read: 5: 0
Received data 255
:?: :roll:
A hozzászólást 1 alkalommal szerkesztették, utoljára kapu48 2008. október 11. szombat, 19:13-kor.
Memória típusa?
24LC nem mindegy!
1 vagy 2 vagy 3 byte a chipen belüli címzése!
Memoria tipusa: 24LC1025
Akkor kel:
I2cwbyte Adresl
I2cwbyte Adresh
Na ez nem segítet! :evil:
http://nearspacevermont.org/downloads/d ... 21941E.pdf
7. oldalon van a címkiosztás.
12. oldal a kezelése a Írás/Ovasásnak.
A HW-ADRRESSbit jó?
A kód a 24LC kisebbjével hogy megy?
Adatlap: 24LC1025
Nem értem de majd próbálkozok!
:oops:
24lc256 vagy 24lc64 működik?
A HW-es címe jól van beírva a chipnek?
I2C inicializálva van?
Kisebb mem ugyan ez az eredmény!
I2CDetect program megtalálja?
Ez a minták közt van, azt hiszem a 4 vagy az 5. program....
3-at talál.
90 0
A0 0, A0 2 címeken
Ezt még nem tudom melyik mi?
De akkor nem stimmel mert én AE – AF címekre küldöm!
:idea:
Hőmérő cím = ?
Óra cím = ?
EEprom cím = ?
Hőmérő cím = H90 - H91 (144 - 145)
Óra cím = HA2 - A3 (162 - 163)
EEprom cím = HA0 - HA1 (160 - 161)
Meg csináltam! :D :D :D
Write: 1: 21
Read: 1: 21
Read: 5: 255
Received data 255
Na jó meg csináltuk! :)
A hozzászólást 2 alkalommal szerkesztették, utoljára kapu48 2008. október 11. szombat, 21:15-kor.
Az I2C írások/olvasások után érdemes meglesni az Err változót. ha ez 1, akkor hibás volt a parancs. Ha 0, akkor jól végre lett hajtva.
Második nekifutás:
'* name                     : i2c_Teszt.bas
'* MegaBoard Chr EEprom Teszt. + Futás idömérés.
'* micro                    : Mega16
'* EEprpm Tip                : 24LC1024
'* EEprom Addres             : Write: HA0 (160), Read HA1 (161)
'* suited for demo          : yes   Flash 13%
'* Fordito    : BASCOM AVR, (V.1.11.9.0)
'* Datum      : 2008-10-12
'* Irta       : kapu48
'* Ha kiveszed a Print-ek elöl a megjegyzést  ( ' ) láthatod az írás, olvasás folyamatát.
'or use the TWI !
I2cinit
Declare Sub Write_eeprom(byval Addresl As Byte ,byval  Value As Byte)
Declare Sub Read_eeprom(byval Addresl As Byte ,byval  Value As Byte)
Declare Sub Write_eeprom_dim(byval Addresl As Byte , Byval Kezd As Byte , Byval Count As Byte)
Declare Sub Read_eeprom_dim(byval Addresl As Byte , Byval Kezd As Byte , Byval Count As Byte)
Declare Sub Read_clock()
Const Addressw = 160                                        'HA0   EEPROM   slave write address
Const Addressr = 161                                        'HA1   EEPROM   slave read address
Const Addresh = 0                                           ' EEprom H address
Dim S As Byte , M As Byte , H As Byte , D As Byte , Month As Byte       'Óra változói
Dim Wm As Byte , Yd As Byte , Value_w(127) As Byte , Value_r(127) As Byte , Kezd As Byte , Count As Byte
Dim B1 As Byte , Addresl As Byte , Valuew As Byte , Valuer As Byte , I As Byte , Maxaddres As Byte       'dim byte
Maxaddres = 127                                             ' EEprom 24_1024 Maximum 0 - 127 byte
Valuew = 0                                                  'Ki irt adat
Valuer = 0                                                  'Be olvasott adat
Print "   START  "
Print " EEprom Törlés "
Call Read_clock()
   Valuew = 255
For I = 0 To Maxaddres
   Call Write_eeprom(i , Valuew)
'   Print "Write cim: " ; I ; " Adat: " ; Valuew             '; Valuew       'write value of three to address 1 of EEPROM
Next I
Print "EEprom iras "
Call Read_clock()
   Valuew = I
Next I
Call Read_clock()
Print "EEprom olvasas "
   Call Read_eeprom(i , Valuer)
'   Print "Read Cim: " ; I ; " Adat: " ; Valuer              'read it back
Next I
Call Read_clock()
Print "Tomb feltoltese "
For I = 0 To Maxaddres                                      ' Tömb feltöltése
     Value_w(i) = I
Next I
Addresl = 0                                                 ' EEprom kezdö cim
Kezd = 0                                                    ' Tömb Value_w(Kezd-et)
Count = Maxaddres                                           ' Átmozgatott Bytek száma.
Call Read_clock()
Print "EEprom T iras "
Call Write_eeprom_dim(addresl , Kezd , Count )              ' EEprom kezdet,  Tömb Value_w(Kezd-et), Ki irt Bytek
Call Read_clock()
Print "EEprom T olvasas "
Call Read_eeprom_dim(addresl , Kezd , Count)                ' EEprom kezdet,  Tömb Value_r(Kezd-et), Be olvasot Bytek
Call Read_clock()
Print "   END "
'sample of writing a byte to EEPROM AT241024
Sub Write_eeprom(byval Addresl As Byte , Byval Valuew As Byte)
    I2cwbyte Addresh
    I2cwbyte Addresl                                        'asdress of EEPROM
    I2cwbyte Valuew                                         'value to write
    If Err <> 0 Then Print "Write Hiba! " ; Addresl ; " Cimen"
End Sub
'sample of reading a byte from EEPROM AT241024
Sub Read_eeprom(byval Addresl As Byte , Byval Valuer As Byte)
   I2cwbyte Addresh
   I2cwbyte Addresl                                         'address of EEPROM
   I2crbyte Valuer , Nack                                   'read byte
   If Err <> 0 Then Print "Read Hiba! " ; Addresl ; " Cimen"
End Sub
    I2cwbyte Addresh
    For I = Kezd To Count
      I2cwbyte Value_w(i)                                   'value to write
      If Err <> 0 Then Print "Write Hiba! " ; I ; " Cimen"
'      Print "Write Cim: " ; I ; " Adat: " ; Value_w(i)
    Next I
'    Waitms 10                                               'wait for 10 milliseconds
End Sub
   I2cwbyte Addresh
      I2crbyte Value_r(i) , Ack
      If Err <> 0 Then Print "Read Hiba! " ; I ; " Cimen"
'      Print "Read Cim: " ; I ; " Adat: " ; Value_r(i)
   Next I                                                   'read byte
End Sub
'   Waitms 10
Sub Read_clock()                                            ' " Read Clock"
    I2cwbyte &HA2                                           'write addres
    I2cwbyte 2                                              'select second register
    I2cstart                                                'generate repeated start
    I2cwbyte &HA3                                           'write address for reading
    I2crbyte S , Ack                                        'read seconds
    I2crbyte M , Ack                                        'read minuts
    I2crbyte H , Ack                                        'read hours
    I2crbyte Yd , Ack                                       'read year
    I2crbyte D , Ack                                        'read day
    I2crbyte Wm , Ack                                       'read weekday
    I2crbyte Month , Nack                                   'read month
   S = Makedec(s)
   M = Makedec(m)
   H = Makedec(h)
   Yd = Makedec(yd)
   D = Makedec(d)
   Wm = Makedec(wm)
   Month = Makedec(month)
   If H < 10 Then Print " " ;
   Print H ; ":";
   If M < 10 Then Print "0";
   Print M ; ":";
   If S < 10 Then Print "0";
   Print S
'   Print D ; "." ; Month ; "." ; Yd ; " " ; Wm
'   Waitms 500
End Sub
Futási időeredmények:
START
EEprom Törlés
16:37:19
EEprom iras
16:37:20
16:37:22
EEprom olvasas
16:37:22
Tomb feltoltese
16:37:22
EEprom T iras
16:37:22
EEprom T olvasas
16:37:22
END
Annyi látszik, hogy csak rövid idők telnek el!
De itt talán óra jelet kellene számolni?
