Arduino 0019
Arduino 0019
Letöltés az arduino.cc honlapról:
http://arduino.cc/en/Main/Software
ARDUINO 0019 - 2010.09.03
[core / libraries]
* Revised Ethernet library (by Christian Maglie). This depends on the
new SPI library, so existing sketches will need: #include <SPI.h>
added to the top of their code.
* Added an SPI library (by Christian Maglie).
http://code.google.com/p/arduino/issues/detail?id=240
* Added aliases for the analog input pins: A0, A1, etc.
http://code.google.com/p/arduino/issues/detail?id=244
* Added a String class.
* Added a shiftIn() function (from Wiring).
http://code.google.com/p/arduino/issues/detail?id=280
* Updated version of Firmata supports Mega and capability querying.
* More accurate delay() function from BenF.
http://code.google.com/p/arduino/issues/detail?id=237
* Re-enabling PWM after tone() ends.
http://code.google.com/p/arduino/issues/detail?id=228
* Added Serial.peek() method.
http://code.google.com/p/arduino/issues/detail?id=270
* Added Stream base class to Serial object (w/ available(), read() and
the write(), print(), and println() functions from the Print class).
http://code.google.com/p/arduino/issues/detail?id=60
* Disabling interrupts while digitalWrite() and pinMode() write to pins.
http://code.google.com/p/arduino/issues/detail?id=146
* Replacing INTERNAL analog reference with INTERNAL1V1 AND INTERNAL2V56 on
the Arduino Mega. http://code.google.com/p/arduino/issues/detail?id=194
[environment]
* Added Arduino Fio to the boards menu.
* Added Arduino Pro and Pro Mini (5V / 16 MHz) to the boards menu.
http://code.google.com/p/arduino/issues/detail?id=81
* Synchronized with the Processing 1.1 code base, bringing various changes.
* Modified the parsing of avr-gcc / avr-g++ output and error messages.
* Toggling RTS on upload for auto-reset with FTDI cables on Linux.
http://code.google.com/p/arduino/issues/detail?id=309
* Adding control over scrolling in serial monitor.
http://code.google.com/p/arduino/issues/detail?id=97
* Added drop-down for selecting line endings to the serial monitor.
http://code.google.com/p/arduino/issues/detail?id=119
* Fixed problem with tabs of the same name but different extensions.
http://code.google.com/p/arduino/issues/detail?id=191
* Allowing third-party hardware platforms to reference programmers defined
in other platforms. http://code.google.com/p/arduino/issues/detail?id=283
[examples]
* Re-organized and numbered for easier access and better progression.
