Bascom 2.0.2.0
Bascom 2.0.2.0
2.0.2.0
- start/stop timer accepts xmega timer names
- Full IDE is translated into Russian.
- config tcXX added for xmega timers
- config acxx added for xmega comparator
- simulator can simulate projects with up to 35 include files.
- dat file for m16U4 added.
- all missing dat files added for Xmega
- loadadr did not took config base into account leading to index error warning for config base 0.
- atmel programmers can load/save in HEX format too.
- ADR2 bug fixed. In 2.0.0.0 the ADR2 could point to the wrong label.
- stk600-PDI support added. When selecting stk600, PDI will be used (for xmega programming)
- $prog accepts lock and fuse bytes for xmega
- options, simulator added to save eeprom state.
- checkfloat() function added by Josef which can check a single or double and returns status about nan,zero,sign and infinity.
- pulseout changed to work with xmega.
- mcs bootloader new reset option. you can send a string for reset. To send special ascii use {}. {027} will send ascii 27.
To send { you have to use the ascii value as well since { is used to send special characters.
- mcs bootloader can use DTR or RTS for the reset.
- xmega gosub=sectic did not set _SECTIC constant.
- xm128 bootloader rewritten for XM32A4, by MAK3
- config DACB , configured DACA.
- split() when array was dimmed the same size as the number to split, the returned count was 1 too high.
- alias bug from 2.0.0.0 fixed.
