Bascom 2.0.3.0.
Bascom 2.0.3.0.
A bascom 2010-12-24-én ismét frissült. Az újdonságok:
2.0.3.0
- mmc-xmega.lib added for using hardware SPI with xmega.
- xmega int() function did not work since it used indirect addressing mode for registers.
- xmega SPI print/input did not use the right counting register, resulting in random read/writes.
- pinout files added
- label and variable names must be unique. this because a function like lookup for example can work with variables as well
previously the variable would be used if both a label and variable existed. now you will get an error and you need to change the name of the label or variable
- updated libusb info in the help
- xmega virtual portmap config
- updated xmega pwm samples and config tcx will set output pin to output in freq/pwm mode when the CCx is enabled
- STK600 PDI programmer did not identified the chip.
- JTAG ICE programming fixed for both USB and COM port. Programmer works only in JTAG mode.
- bit compare bug from 2.0.0.0 fixed
- xm128a3def.dat , tc1 added
- Open File has a sub menu so you can open a file from the samples folder directly.
- bookmark images show larger number for better readability
