Az eredeti forrás itt található: VGA video adapter
http://www.serasidis.gr/circuits/AVR_VGA/avr_vga.htm
Maga a HW. roppat 1*ű! Csak a programot nem tudom lefordítani!
Van benne 1 Szerintem a Videó memória tömbje, amit nem talál meg a fordító!
Mi lehet ez a 562. sorban : SPDR = PRG_RDB(_ptr1 + (* _ptr++)*vga_symbol_height/2);
Hibajelzés: Nincsen definiálva „PRG_RDB”????
//Simplest universal VGA(20x20)/PAL(38x20) terminal
//For sync used Timer0 Timer1
//To avoid flickering while receive UART data,
//recommend to send UART data after VSYNC during
//10-20 VGA lines timing (around 300-600 mks)..
#include <avr/io.h>
#include <avr/signal.h>
#include <avr/sleep.h>
#include <avr/pgmspace.h>
#include <string.h>
#include "symbol_tbl.h"
#define true 1
#define false 0
#define NOP asm("nop")
//Global definitions for VGA render
#define vga_field_line_count 525 //standart VGA quantity lines
#define vga_symbols_per_row 20 //symbols quantity per horizontal
#define vga_row_count 20 //symbols quantity per vertical
#define vga_symbol_height 24 //rendered symbol height
//Global defenitions for render PAL
#define pal_field_line_count 312 //standart PAL/SECAM quantity lines (interlaced 625~312*2)
#define pal_symbol_height 12 //rendered symbol height
#define pal_symbols_per_row 38 //symbols quantity per horizontal
#define pal_row_count 20 //symbols quantity per vertical
#define sbi(port, bit) (port) |= (1 << (bit))
#define cbi(port, bit) (port) &= ~(1 << (bit))
#define PRG_RDB pgm_read_byte
//Makro for video handle
//Video
#define video_off DDRB=0x90
#define video_on DDRB=0xB0
//HSYNC
#define hsync_off sbi(PORTD,3)
#define hsync_on cbi(PORTD,3)
//VSYNC
#define vsync_off PORTD=0x04
#define vsync_on PORTD=0x00
#define check_PAL_jumper bit_is_clear(PINC,1)
//Global variables
volatile unsigned char str_array[pal_symbols_per_row*pal_row_count+1]; //Chars array for display buffer
volatile unsigned int current_symbol; //Current symbol number at terminal
volatile unsigned char video_enable_flg;//flag for enable render
volatile unsigned char raw_render;//Current row at display buffer for render
volatile unsigned int linecount;// current line for render
volatile unsigned char y_line_render; //Current Y-line at symbol for render
//Store strings data at Program Space, to avoid RAM leakage
const char str1[] PROGMEM = "Simple PAL terminal v1.2 UART-19200bps";
const char str2[] PROGMEM = "Simple VGA terminal";
const char str3[] PROGMEM = "v1.2 UART-19200 bps";
static void avr_init(void);
//All VGA sincronize made here..
SIGNAL(SIG_OVERFLOW0)
TCNT0 = 0xC3; //reload counter value
//******Syncronization Handler********
//Count number of lines
if (++linecount == vga_field_line_count)
linecount = 0;
//clear pointers for render display buffer
raw_render = 0;
y_line_render = 0;
//Make Vsync length 2 VGA lines
if ((linecount == 10 )||(linecount == 11 ))
//Make here vertical syncronization & HSYNC syncro level on
vsync_on;
//.. & HSYNC syncro level on
vsync_off;
video_enable_flg = true;
if (linecount < 45)
video_enable_flg = false;
//Add to avoid flickering at top display
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
//Forming current string for rendering
if (++y_line_render == vga_symbol_height)
raw_render++;
y_line_render = 0;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
hsync_off; //HSYNC syncro level off
//All PAL sincronize made here..
SIGNAL(SIG_OUTPUT_COMPARE1A)
if (++linecount == pal_field_line_count)
linecount = 0;
raw_render = 0;
y_line_render = 0;
//Invert HSYNC for VSYNC
if (linecount > 305 && linecount < 309)
sbi(PORTC,0); //inverted syncro level on
char i = 15;
while (--i)
{ NOP;}
//And "black" = 8 mksk;
cbi(PORTC,0); //inverted syncro level off
//Make HSYHC = 4 mksk;
cbi(PORTC,0); //syncro level on
char i = 30;
while (--i)
{ NOP;}
sbi(PORTC,0); //syncro level off
if ((linecount < 40) || (linecount > 278))
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
if (++y_line_render == pal_symbol_height)
raw_render++;
y_line_render = 0;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
void spi_init (void)
//Set SPI PORT DDR bits
sbi(DDRB, 7); //SCK
cbi(DDRB, 6); //MISO
sbi(DDRB, 5); //MOSI
sbi(DDRB, 4); //SS
SPSR = 1 << SPI2X;
SPCR = (1 << SPE) | (1 << MSTR); //SPI enable as master ,FREQ = fclk/2
//That's a great pity, that we can't work with SPI with FREQ = fclk,
//because may be possible build terminal up 40 symbol per row!!!
static void uart_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = 0x86; //8 bits data & 2 stop bits
//UART SPEED 19200 bs
UBRRL = 0x33; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
//UART SPEED 38400 bs
//UBRRL = 0x19; //set baud rate lo
//UBRRH = 0x00; //set baud rate hi
//UART SPEED 76800 bs
//UBRRL = 0x0C; //set baud rate lo
//UART SPEED 115200 bs
//UBRRL = 0x08; //set baud rate lo
//UART RX Enable
UCSRB = (1 << RXEN);
static void pal_terminal_handle(void)
// Parser received symbols from UART
while(UCSRA & (1<<RXC))
unsigned char current_line, received_symbol;
received_symbol = UDR;
//Check for overflow display buffer
if(current_symbol == (pal_row_count*pal_symbols_per_row))
//Clear display buffer
unsigned char i = pal_row_count;
char * ptr;
//Set pointers for clear string array
ptr = &str_array[0];
while(i--)
//Don't use here loop, to fastest clear display buffer
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
current_symbol = 0x0;
switch ( received_symbol )
//BackSpace
case 0x08:
if(current_symbol)
str_array[current_symbol] = 0x0;
str_array[--current_symbol] = 0x0;
break;
//TAB
case 0x09:
if((current_symbol + 5) < (pal_row_count*pal_symbols_per_row))
//Add 5 Space
current_symbol += 5;
break;
//RETURN
case 0x0D:
current_line = current_symbol / pal_symbols_per_row;
if((current_line) < 19)
current_symbol = current_line*pal_symbols_per_row + pal_symbols_per_row;
break;
default: str_array[current_symbol++] = received_symbol;
void pal_render(void)
unsigned char i;
char * _ptr;
const char * _ptr1;
//Initialize display buffer with StartUp strings
strcpy_P(&str_array[pal_symbols_per_row*(pal_row_count-1)],&str1[0]);
//Enable global interrupt
asm ("sei");
for(;;)
//Wait compare interrupt signal from Timer1
sleep_mode();
//Check symbol on UART
if (UCSRA & (1<<RXC))
//Parse received symbol
pal_terminal_handle();
//Can easealy add here RX polling buffer
//to avoid display flickering
continue;
//To make horizontal shift rendered image
i=14;
while(i--) NOP;
//Check visible field
if(video_enable_flg)
//OK, visible
//Main render routine
//Set pointer for render line (display bufffer)
_ptr = &str_array[raw_render * pal_symbols_per_row];
//Set pointer for render line (character generator)
_ptr1 = &symbol[0][y_line_render];
//Cycle for render line (Ciklus render vonal)
i = pal_symbols_per_row;
video_on;
while(i--)
SPDR = PRG_RDB(_ptr1 + (* _ptr++)*vga_symbol_height);
//That's a great pity can't shift data faster (8Mhz at FOSC=16Mhz)!!
//Ez egy nagy kár nem shift adatok gyorsabban (8MHz a FOSC = 16MHz)!
NOP;
NOP;
NOP;
//Delay for draw last symbol
i=6;
while(i--) NOP;
video_off;
//Not visible
//Can do something else..
//******Cursor handle
//Count frame
static unsigned int framecount;
framecount++;
//Here draw cursor
if (framecount&0x800)
str_array[current_symbol] = ' ';
str_array[current_symbol] = 0x7F;
//You can add here your own handlers..
}//for(;;)
static void vga_terminal_handle(void)
if(current_symbol == (vga_row_count*vga_symbols_per_row))
unsigned char i = vga_row_count;
char * ptr;
while(i--)
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
*ptr++ = 0x0;
//BackSpace
case 0x08:
if(current_symbol)
break;
//TAB
case 0x09:
if((current_symbol + 5) < (vga_row_count*vga_symbols_per_row))
//Add 5 Space
break;
//RETURN
case 0x0D:
current_line = current_symbol / vga_symbols_per_row;
current_symbol = current_line*vga_symbols_per_row + vga_symbols_per_row;
break;
void vga_render()
unsigned char i;
char * _ptr;
const char * _ptr1;
//Inicializálása kijelző puffer StartUp húrok
strcpy_P(&str_array[vga_symbols_per_row*(vga_row_count-2)],&str2[0]);
strcpy_P(&str_array[vga_symbols_per_row*(vga_row_count-1)],&str3[0]);
asm ("sei");
for(;;)
sleep_mode();
vga_terminal_handle();
continue;
//Check visible field Ellenőrizze a látható mező
//OK, visible
//Állítsa be a mutatót teszik vonal (kijelző bufffer)
_ptr = &str_array[raw_render * vga_symbols_per_row];
_ptr1 = &symbol[0][y_line_render >> 1];
i = vga_symbols_per_row;
while(i--)
video_on;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
video_off;
//Not visible
//Count frame
framecount++;
//Here draw cursor
}//for(;;)
int main(void)
avr_init();
//Check pin VGA/PAL
if(check_PAL_jumper)
pal_render();
vga_render();
return(0);
//Set pin jumper VGA/PAL
cbi(DDRC,1);
sbi(PORTC,1);
//Enable SPI
spi_init();
//init uart
uart_init();
//Set power mode
set_sleep_mode(SLEEP_MODE_IDLE);
//Check pin mode VGA/PAL
//init PAL SYNC port
sbi(DDRC,0);
//C.0 is sync:1000 ohm + diode to 75 ohm resistor
//MOSI is video:330 ohm + diode to 75 ohm resistor
// Initialize Sync for PAL
OCR1A = 1024; //One PAL line 64us
TCCR1B = (1<<WGM12)|(1<<CS10);//full speed; clear-on-match
TCCR1A = 0x00; //turn off pwm and oc lines
TIMSK = 1<<OCIE1A; //enable interrupt from Timer1 CompareA
//init VGA SYNC ports
//HSYNC
sbi(PORTD,3);
sbi(DDRD,3);
//VSYNC
sbi(PORTD,2);
sbi(DDRD,2);
// Initialize Sync for VGA
TCCR0 = 0x00; //stop
TCNT0 = 0xC3; //set count, One VGA line 31.77us
TCCR0 = 1<<CS01; //start timer with prescaler select 1/8
TIMSK = 1<<TOV0; //enable interrupt from Timer0 overflow
return;
Ui.: A hiba kijavítva! Most már fordítható.
Következik a tesztelés!
